Online: GGUser762, Stuart
2025 Road Glide Questions re Stage 1 upgrade and Bluetooth Communications
  • BigKangaroo
    BigKangaroo
    1 month
    Happy New Year to all HD riders. I just purchased a 2025 Road Glide and done a massive 600 klms thus far. I am really keen on opinions on the best but least expensive slip on mufflers purely to get a nice note. I am not sure what a Stage 1 upgrade would cost but I have been told it is around 3.5K. The 117 engine does more than I will ever need so just after the sound. Others opinions here would be good. In addition, I ride mostly with the bag of strife on the back and would like to get opinions on a Bluetooth or whatever system so we can talk to each other, take phone calls etc which integrates with the bikes built in system on the right side handle bar controls. Thanks heaps for opinions.
  • RaffRKS
    RaffRKS
    14 days ago
    On my Road King I originally had the stock mufflers modified by Geelong Harley. They also replaced the air filter element and tuned it. It had a nice sound to it that wasn't to loud but sounded like it should.
    There is no cheap way around it unfortunately and you really need to have them tuned on a dyno to get the best result as the factory tune is very lean. After a tune it will ride so much better.
    I kept it this way for 8 months then went a bit further by having Gellong fit a set of their modified headers and a Woods 22xe cam. I also fitted an extreme wedge air cleaner and an alloy inlet manifold.
    My bike is now loud and goes much better.
  • obisteve
    obisteve
    14 days ago
    Bluetooth communication with your passenger sounds like a sure way to be possibly fatally distracted by screaming in your ears while you're trying to concentrate absolutely on avoiding the car that's just turned across in front of you.
