Burly Slammer shocks on 1200 Sportster
  • shep23
    shep23
    2 months
    Hey all, Have the burly slammer shocks on my bike and I'm getting the occasional loud squawk that sounds like LH rear side of bike. I suspect the shocks are the issue. I pulled them and greased the mounting bolts which I think fixed it for 20-30 kms but then it started again. Has anyone had similar issue and did you find a fix?
  • obisteve
    obisteve
    2 months
    Any witness marks under the mudguard of the tyre hitting the guard?
