Foot clutch conversion, jiffy stand extension
  • Trunksie
    Trunksie
    3 months
    Hey legends,
    Has anyone done a foot clutch conversion on a sporty.
    Been looking at the prism supply kits but they only do mid control kits and was wondering what else is out there.
    EDIT: Forgot to put it in but what are you guys doing i regards to jiffy stand extensions?
    Are you buying, fabbing a new one or are you cutting and extending the existing?
    Cutting welding the existing one is the way im leaning
    Trunksie
  • obisteve
    obisteve
    3 months
    Trunksie, I don't have any pics, but I helped a mate do a foot clutch conversion on a 4 speed Evo Sporty in the 90's. It was a suicide clutch and jockey shift he did and I'm assuming that's what you want.
    It was a bit of a butchers job but he was into rat bikes.
    He already had a set of SE 5 speed Sporty forward controls massaged to fit, easy enough to put on the left side, not so much on the right.
    He cut the clutch cable about 50mm out of the primary, used standard wire rigging fittings, eyelet and clamp to put an eyelet into the end of the cable. He put a small stainless  shackle into the eyelet and hooked it to some light chain attached to the eye on the gear lever, which he put on upside down, with another small shackle. He already had a SE heavy duty clutch spring in there and he relied on it to lift the old gear lever, now the clutch pedal, back up. He cut a V shaped piece of checker plate, sized to fit to the rear 2 primary cover screws, welded a steel bush to the apex of the V, and pivoted a length of steel rod off there, hooked to the gear shift shaft with the adjustable link rod that that had been been in the gear shift. I think he had to bend that around the clutch cover. He drilled and tapped a pool ball to go on top of the jockey shift.
    Does that make sense? It looked rough, but worked OK with a bit of adjustment to the length of the chain. I rode it a few times, but never got the skills needed to use it smoothly. OK on country roads but a horror show in traffic.
    Extended side stand?
    Are you putting longer fork tube in?
  • Trunksie
    Trunksie
    3 months
    Quoting obisteve on 04 Nov 2025 10:56 AMedited: 04 Nov 2025 11:17 AM
    Yeah mate I sorta see what your saying ive seen a few big twins do something similar.
    Have a look at prism supply kits.
    All up they are about $1200 delivered
    They replace the derby cover and you remove the clutch cable and they supply a bolt to plug the hole in the primary cover.
    I want to do the whole thing in my garage so trying to keep fabrication to a minimum I have access to a workshop 15 minutes away.
    Yeah I need to extend the jiffy stand.
    Im rebuilding the forks with 6"+ and im dropping the arse a couple of inches with some progressive springs which would eventually be a hardtail if it isn't a nightmare with engineering.
  • obisteve
    obisteve
    3 months
    However it turns out please keep posting pics, it would be good to get some Sporty chopper pics to balance up those of old blokes bikes. 🙂The Prism Supply kits look good Trunksie, but as you say limit you to mid controls, which does lower the cool factor.
    If your looking at that kit, I've gotta assume it's  5 speed pre rubbermount bike?
    A suggestion would be to buy the Prism Supply jockey shift kit, also buy a set of TC bros forward controls, use the brake side as is. On the left side, use the kits gear lever, cut the tab off it that by design pushes on the kits gear linkage and have it TIG welded onto the top of the lever, and do the chain linkage I mentioned last post.
    First time you will have ridden with +6" fork tubes?
    Enjoy!
  • Trunksie
    Trunksie
    3 months
    Quoting obisteve on 05 Nov 2025 01:07 AMedited: 05 Nov 2025 01:10 AM
    Enjoy!
    Thanks mate ill have a look into them.
    I was going for that japanese chopper look.
    Ive ridden 4 inch overs, not that interested in ride condition ive got a road glide st that ive spent a fair bit on that is my main ride while this will be a friday night bar hopper.
    Ill let you know how I got.
    Yeah looking at a 96-2003 rigid mouth carbi
  • Rextheute2022
    Rextheute2022
    3 months
    I got nuffin , but 'japanese style you say '
    Check this fella - not much talky , but very clean work - and does some vids of the shows .
    Japanese style is wild -  ' go for it '
  • Trunksie
    Trunksie
    3 months
    Quoting Rextheute2022 on 05 Nov 2025 08:05 AMedited: 05 Nov 2025 08:05 AM
    Awesome, thanks for that mate.
    Had a look at his videos, that orange one is off its head.
    This is one of the japanese channels I follow. This is the style I like but a sporty not a shovel.
    Thanks again mate
  • Stuart
    Stuart
    3 months
    Quoting Trunksie on 05 Nov 2025 09:11 AM
    Thanks again mate
    Bit of a rabbit hole that link :-)
  • Rextheute2022
    Rextheute2022
    3 months
    ohhhh noice - into the hole I go !
