LH control module.
  • HD17
    HD17
    4 months
    Just wondering if anyone has had drama on a twincam fatboy s with the left hand control not working. it was working and no nothing is working on that side but the right hand control is working. bars were changed a long time ago. checked the wiring and under the tank. dont really wont to buy a new one until I know its stuffed. any help would be great. cheers.
  • Hilly
    Hilly
    4 months
    I'd take a stab at the connection in the bars, sounds like the culprit.
  • HD17
    HD17
    4 months
    Thanks Hilly will try that. cheers
