2009 Street Glide Stereo Issues
BigKangaroo
4 months
Hi all. I have a 2009 Street Glide and the stereo just stopped putting out sound. The head unit lights up but no sound. I have tested the speakers and done other things and am pretty confident it is the unit. It is the stock standard Harmon Kardon BE 7680 stereo and the problem is that I can not get a replacement. Does anyone have any heads up on any other stereo that would suit the same wiring and fit in the slot or whether there is some form of adapter to suit this purpose. I know I can use ear buds but the missus does not want this so here I am seeking a solution.
Cheers and TIA
Bear
4 months
That’s a common fault with the oem harmon kardon head unit. If you could get a second hand replacement you wouldn’t bother as they’re pretty shit. I replaced mine years ago and there quite a few options then that worked with oem wiring and handlebar controls. Dunno what is available now as it hasn’t been a common head unit since 2013.
Search this forum for my old thread titled, “stereos on tourers”
B0nes likes this post
Hilly
4 months
Aftermarket still caters, you get what you pay for, HogLights have a flash one, depends if you have a Harman amp though, let google be your friend 😁
BigKangaroo and paulybronco like this post
B0nes
4 months
https://garagebaggerstereo.com/products/sony-dxs-m5511bt-marine-audio-package
Look for something like this, suitable for marine use so shouldn't crap out if you get caught in a storm. You can get a plug in kit so your bar controls still work if needed. Sounds like the same problem as my 2011 Ultra has. To be honest I haven't replaced mine as I found that I don't miss it at all.
BigKangaroo likes this post
dicko
4 months
The part that fails in these units is the 4 channel amplifier. You can get the replacement chip on the net. It is difficult to replace . you need very good skills to remove the old chip and get the new one in without further damage. I have done a couple and they worked.
BigKangaroo and softfat like this post
4 months
I know nothing about the Glide audio units, but worked in electronic repair forever .
I was interested so I looked around, and I'm guessing this is the repair dicko has mentioned ?
A simple enough job, but how long it lasts until it dies again- who knows !!
https://www.hdforums.com/forum/audio-systems/1226049-hk-radio-repair-diy.html
Hilly, B0nes and softfat like this post
dicko
4 months
Yep thats the repair . the new ones do last ok.
3 months
I have had tw0 stds , one under warranty and they are shit. Ended up with a hogtunes amp and a aftermarket headunit.
imoo6170
3 months
Don't know where you are located but I took mine (I had to pull the unit out of the bike, not hard) to a repair place (but it was 15 plus years ago) and they did fix it. They may still repair them not sure - JVP Service Centre, 90 Sydenham Rd, Marrickville NSW 2204
BigKangaroo
1 month
Hey thanks for everyone's thoughtful and genuine replies. Just as an update, a company called "Hog Lights" in Brisbane supplies after market stereo's and he is a great fella and always available to help. I treated myself a week ago and purchased a new 2025 Road Glide and OMG, the 117 M8 engine with stock pipes goes way too hard for an old fart like me but bloody hell I love it. Gunna put on some slip on pipes and not do a Stage 1 upgrade because it just does not need it. Cheers all and safe riding. Darren
1 month
The new M8's do perform, no question !
Did you trade the old girl in still with a broken stereo ?
That's one way to fix it 😉🤣
Hilly likes this post
Hilly
1 month
That hoglights stereo looks the goods, I gotta be honest though, I love that one note song, courtesy Bob Seger.
obisteve likes this post
BigKangaroo
1 month
Quoting speedzter on 09 Jan 2026 10:46 PM
Ha Ha. No, still got the old girl. I am trying to give it to my son but his wife has other ideas. Bloody women !!!
Hilly and imoo6170 like this post
