How far can 103 twin cam heads be safely shaved.
  • FatMat
    FatMat
    5 months
    Just wondering how far 103 twin cam heads can be shaved and what kind of compression change can be expected? I brought a 2015 fatboy in Feb this year that only had a 1000's k's on it. I've put about the same on it since then. Considering upgrading the cam. I've noticed most of the upgrade/stage kits increase comp by changing the pistons and that most of these pistons have valve wells for valve clearance in them. I like the look of the fuelling reaper 525 cam and also want to port the heads and upgrade the pushrods. I believe they like comp between 9.7-10.5. And I believe a standard 103 is about 9.6. Is possible to bump the comp up within this range by shaving the heads? Just seems a shame to throw two hardly used pistons over my shoulder.
    Thanks in advance for any help.
    Hope I'm not completely off track.
  • FatMat
    FatMat
    5 months
    Quoting FatMat on 18 Aug 2025 09:58 AM
    Sorry 9.7:1*, 10.5:1* & 9.6:1*
  • John.R
    John.R
    5 months
    Where does your CR and CCP land with thinner head gasket options?
  • FatMat
    FatMat
    5 months
    Quoting John.R on 19 Aug 2025 12:29 AM
    I'd be lying if I said I understood what ppl are talking about in regards to corrected compression and all that jazz. Would changing a head gasket really make any noticeable difference? I'm guessing maybe a combination of shaving and the gasket. I really have no idea of what sort of difference in compression to expect from shaving the heads or if this Is even viable option.
    5 months
    50thou or 1mm - 2mm were always good options on the Evo to bump up the Compression and HP.  Always best to remove from cylinder base though tbh. (something to do with valve lift geometry)
  • FatMat
    FatMat
    5 months
    OK cheers.
  • John.R
    John.R
    5 months
    Quoting FatMat on 19 Aug 2025 12:52 AM
    http://www.bigboyzheadporting.com/TwinCamComp.htm
    Plug all your figures in there. But in short, yes it makes a difference, particularly if done in combination with other mods.
     I wouldnt be just be shaving heads an arbitrary amount. Youd also want to consider your deck height. No use compensating with pistons that are low in the bore by knock a bunch off the head.
  • FatMat
    FatMat
    5 months
    Thanks! Yeah fair call.
  • Lushy
    Lushy
    5 months
    If the squish is set at 1mm. The 103 will have 9.8:1 compression. Fuelling 543 is a winner at that.
  • FatMat
    FatMat
    5 months
    Yeah cool, that's the kind of information I was chasing.
    Thanks!
