Hybrid motorcycles
Hybrid motorcycles
dicko
7 months
maybe this??
dicko
7 months
and this/
https://www.kawasaki.eu/en/Motorcycles/EV_HEV/Ninja_7_Hybrid.html
dicko
7 months
https://global.honda/en/tech/Hybrid_System_PCX_HYBRID/
Jay-Dee
7 months
BARF, BARF and BARF, no thanks.
Stuart
7 months
I've always had a soft spot for big Kwakas. If I was 30 or 40 years younger, I'd have a go at the Ninja - sounds like it would go like stink.
What is the motivation for the production of these bikes? I can kind of see it from a performance perspective. Though how much more performance do you need given what is already on offer? I guess if some is good, more must be better :-) Fuel consumption? Not sure. I'm not certain this is a problem that needs to be solved on the emissions front - I think motorcycles are at the bottom of the carbon producing heap. While it all adds up, I'd think you were chasing percentages in this regard.
boxa
6 months
Quoting Stuart on 17 Jul 2025 09:19 PM
edited: 17 Jul 2025 09:24 PM
I'm with you on the big Kwackas , got myself a gtr1400 10 months ago , i have a 650 v strom which was my main bike , bullet proof , cheap to run and good for a bit of dirt , my low rider was the 2 up bike , bike when my mates go out and the bike for overnighters or longer jurneys ,, since i got this kwacka , there both gathering dust , its just so smooth , handles so well , and that powerband is awsome , , there an awsome bike , biggest problem i have with it is that power once your up around 100 klm ph its only a slight twist and your off like a herd of turtles jeez there a fast bike , i have to force myself to use the other bikes , and even then i grab the kwacka fob ,, i only put them back when i remind myself they don't make them any more in a few years they will be hard to find , lucky there known to do 2-300 thousand klm if looked after
Stuart and Neale like this post
