What bolt?
  • bikenut57
    bikenut57
    8 months
    G'day all. Trying to determine the type of caliper mounting bolt on my 2018 Street Glide. It's not torx head, possibly double hex? Any info would be appreciated.
    Cheers!
  • Soapbox2627
    Soapbox2627
    8 months
    its a fancy bolt that takes a standard 12 point socket, I only took off the wifes triglide front wheel last week and cant remember the size, I even asked the dealer about it and he said that it was a normal size socket
    8 months
    yep...12 point bolts.  best to buy the right 12 point socket as they fit like a glove!
  • bikenut57
    bikenut57
    8 months
    Quoting tussuck on 17 Jun 2025 10:47 AM
    Cheers for that mate.
  • bikenut57
    bikenut57
    8 months
    Quoting Soapbox2627 on 17 Jun 2025 10:12 AM
    Thanks for the info.
