Online:
Soapbox2627
Swapping parts M8 Softails
Frankly83
9 months
Hi,
My wife and I both own M8 Softails.
My question is, if I wanted to go from 117 to 128 or 131 and the package comes as a complete kit, what parts could I shift from a 2023 117 to a 2019 107?
Would the heavy breather fit? I don’t like how far it sticks out.
I assume intake manifold and cam would slot straight in? And would the injectors be able to be used?
Hers: 2019 FLSL
- V&H big shots
- S.E. Air filter
- V&H FP4 (also has the SE Pro street tuner)
- SE447
- S.E. Adjustable pushrods black
Mine: 2023 FXLRS
- SPC Big Bore ss
- S.E. High flow element
- PV tuner
- CR480MT cam
- S.E. High flow injectors 5.5gps
- S.E. 55mm intake manifold
- S.E. Adjustable pushrods chrome
- S.E. High capacity tappets
- S.E. Heavy duty clutch springs
- Billet Compensator
Hilly
9 months
All the outside stuff would fit, you could use the stock injectors but you would need to check the duty cycle, I'd go straight to the 5.5's, cam, lifters would also be fine, that cam is actually a great fit in a 107 apparently, but I'd get a better tuning device, assuming a dyno tune with a competent tuner and device your missus will be grinning from ear to ear with the 480.
Frankly83 likes this post
