Online:
Soapbox2627
Throttle problems
Throttle problems
Fatt
10 months
I have just bought a 2017 Fat Boy with the later throttle with no cables. Problem is it is jerky at low speed and when hitting bumps in road. I have had it back to dealer twice and they are saying there is nothing they can do , does anyone have a solution ?.
Thank you
Hilly
10 months
Is it stock Fatt?
Steve L
10 months
Even if it's pretty much standard they can be like that from new. They are setup with a generic tune. The best solution I think would be to get it on a dyno. If you are thinking about do any mods, ie air, exhaust or cams, then do that first, otherwise you would need to get it redone on the dyno again.
9 months
TPS issue maybe. They give jerky throttle at low steady speeds - say 50-70kmh
Hilly
9 months
Could be quite a few things, but we will never know.
tussuck likes this post
