Online:
Hilly
BDL lock up clutch
BDL lock up clutch
rock38
9 months
Gday Guru,s
I bort a twin cam R-King with a 107c.i and a bdl ball bearing lock up clutch in it…It has a pressure plate spring.
I hav since rebuilt engine to a 124 , if anyone knows what these bdl clutches are good for h.p and torque wise plz share or shld i go Barnett strait off the bat ?
Cheers All
Rock.
Hilly
9 months
G'day rock, if the pack is in good order it should hold it no worries being of the centrifugal type, harder you rev it the harder it will hold.
rock38 likes this post
9 months
That's a good question, and I don't recall seeing an answer .
Do you have a full BDL clutch setup, or just the Lockup ball bearing pressure plate ?
Hilly
9 months
I think I mixed up in my head what you have rock, is it this one?
rock38
9 months
Yes that looks like it…I bort the bike with it installed already so I’m not 100% on the plates but the rest is the same…I’m not a web expert I struggled to find any info on the thing!!
Hilly likes this post
9 months
It makes quite a difference depending on what setup you have .
A quick way to tell is to look at the clutch plate width .
The full BDL clutch setup will handle a lot of power .
rock38
9 months
I will check that out tonite when I get home thanks speedzter
Curious tho…do u think it will handle a R.P.I built s&s 124 ?
I’m not gona b drag strip racing it but I do ride like a temporary resident at times !!!
Hilly
9 months
This is where my brain went when I first read your post......
9 months
I am using just the BDL ball bearing lockup plate combined with a Barnett extra plate kevlar clutch.
It handles my custom 120" no problems, but it is in a lighter Dyna .
rock38
9 months
Yeh I’m hearing ya…I think I’ll go the Barnett route and keep that clutch for my dyna if it ever needs it also.
Cheers for your feedback .
