Online:
Wanderer57
Trickle Charger
Trickle Charger
jake1259
1 year ago
Ive recently purchased myself a 2024 Low Rider S, The charger plug that hangs out of the left side of the bike now has a a 3rd terminal as opposed to the original plug only having 2. Does anyone know if this requires a specific charger or can a normal one be used? Thanks in advance
beaglebasher
1 year ago
Have you traced the wires and confirmed that they go directly to the battery terminals?
As your bike only has two terminals on the battery, you would need to figure out where the third wire is going.
Try and take a pic and put it up.
