Pre-Load setting 2023 Heritage - single rider with occasional pillion
  • ATilsley169
    ATilsley169
    1 year ago
    I have a 2023 Heritage, just bought.
    I weigh 80kg...and I ride 95% of the time solo.
    There are occasional weekend rides with light luggage.
    I'm wondering what the best pre-load setting to use.....eg, if it is set to 1, then that means no capacity to add pillion or extra luggage without adverse result.
    Do I take a punt and aim for 2-3 to cover my bases? I don't really want to take the seat off to adjust this every time I have a pillion.
    At the end of the day, I'm after plushness.
    Thanks.
  • Daffy
    Daffy
    1 year ago
    Quoting ATilsley169 on 30 Jan 2025 12:13 AM
    Thanks.
    Yes I have been down this road. I have a seriously bad back and I had mine set on what they say in the manual. A mate was following me and when we stopped he said it looked like I was bottoming out. I,m 90 kg no passenger and mines set to 3 and a bit   You just have to experiment a bit. How many kilometres has the bike done?  I had my front forks reconditioned. Mines a 21. Done 35000. Had progressive springs put in at the same time. Oil was really bad. I’m happy to talk to you if you need. Pm me your number. Where are you located. Cheers Daffy
  • ATilsley169
    ATilsley169
    1 year ago
    Thanks.
    Quoting Daffy on 31 Jan 2025 12:14 AMedited: 31 Jan 2025 12:38 AM
    Thanks Mate. My bike only has 2,700Kms....so I'll keep checking this matter over the next few weeks. I haven't checked, but I suspect it's on 2 setting....which works well. Mrs came for a short ride on the weekend, and the bike performed well. Regards.
  • Neale
    Neale
    1 year ago
    I run my 2019 Heritage on the 4th mark. I’m 97 kgs and it’s better to ride for me at that setting.
