Low fuel light
Low fuel light
PappaSmurf
1 year ago
Hi all
I recently purchased a 2009 FLHTCU (Ultra Classic) and the fuel light comes on when I fill it up, but doesn’t come on when I get low on fuel. My first guess is something is connected back to front. Before I pull the tank apart does anyone have any idea where to look first?
1 year ago
If i recall there's a electrical connection under the tank but it only plugs in one way. Check the fuel sender inside the tank would be my first look.
Hilly
1 year ago
Some fucker may of done some dodgy shit in the past, I'd start with wiring on the outside, then the sender unit itself.
STEAMER
1 year ago
Take the console off tank and should be plug there to power the fuel pump and i think gauge
