Online: Hilly, speedzter
TBR 2-1 pipes
  • JFE
    JFE
    10 months
    Hey all. My 2015 Fat Bob is in need of a new gaudy. Had D&D Fat Cat since new but now front header pipe snapped near cylinder and can’t be welded.
    Always preferred 2-1, open to colour (stainless or black).
    Looking to replace with TBR 2-1 Comp-S. Or perhaps V&H Power Pro. Both caught my eye on Rollies site. Anyone got some experience with these on their Dyna’s or other HD’s?
    I did a forum search and most seem happy. Would maybe go Fat Cat again but had first pipe header (rear cylinder) welded a few years back and now snapped the front!
    Thanks.
  • WideglidingNZ
    WideglidingNZ
    10 months
    I'd go for the D&D again(out of the 3 pipes you named) apparently a good performing exhaust, Bassani do nice pipes too
  • 408
    408
    10 months
    The Fat Cat is the best pipe you will get for that bike.
    I am curious that the header can not be welded.
    Sounds like you may have a mounting problem because there should not be any movement creating fatigue between the exhaust ports and the headers.
    Do you use the tab below the cam cover when mounting the pipe ?
    I would snug the transmission bracket up tight and leave some play in the 9/16" bolts .Have a loose fit at the collector and the tab at the cam cover and snug the exhaust header brackets up tight.
    Fit a spacer at the cam cover tab if required to support the header fit at the exhaust ports.
    Tighten everything up.
    Should be a good tight stress-free fit.
    Use cometic race gaskets.
  • JFE
    JFE
    10 months
    Quoting 408 on 22 Jan 2025 12:59 AM
    DM sent on this. Thanks.
  • JFE
    JFE
    10 months
    Quoting WideglidingNZ on 21 Jan 2025 11:16 PM
    Thanks. You are probably right but feel like a change from D&D after the Fat Cat (agree, great pipe). Interested in ppls experience in the TBR.
    10 months
    Didn't think V&H made the pro pipe for Dyna anymore... only 2:1 shown is STAINLESS 2-INTO-1 UPSWEEP. I had Pro Pipe on my 2007 Street Bob and whilst it had good performance and awesome sound, it was a humungus pipe. Mine was one of the first and didn't have heat shields back then so I wrapped mine. They did have a shorter version for later Softails when I looked in 2022 when I bought Bassini
  • Lushy
    Lushy
    10 months
    Is your engine a stock one or modified?
  • JFE
    JFE
    10 months
    Quoting Lushy on 22 Jan 2025 04:00 AM
    Hi Lushy - Stage 1 with SE Heavy Breather and a tune for the Fat Cat. Maybe in the future put a cam in but no more then that.
  • Lushy
    Lushy
    10 months
    The TBR pipes are more top end biased, but with a stock motor not massive differences will show. You want a 2 into 1?
  • JFE
    JFE
    10 months
    Quoting Lushy on 22 Jan 2025 10:06 AM
    Yeah mate. Always liked the 2-1 on the Fat Bob.
  • JFE
    JFE
    10 months
    After research and hearing views, I ordered a 2-1 D&D Bob Cat system.
    Was tempted by others but all roads led to D&D for me and went Bob Cat for something different over the Fat Cat system I’ve had for a 10 years. Will put up a pic in a few weeks (back order).
    Thanks for those that took the time to offer opinions.
  • JFE
    JFE
    9 months
    Got the Bob Cat installed.
    I think I’m in love. So ugly it’s beautiful. Carbon Fibre on a HD can look sweet.
    D&D seems to have improved the black coating on the headers - seems hardier and the slight gloss in it is good. Different sound - old school HD at points. Bit louder at start but slightly quieter when rider compared to the Fat Cat.
    Runs different, as you’d expect too - encourages more revs. So it’s like I have a whole new Fat Bob! Tried a flash tune from dealer … Will see how it goes. Can get tuned otherwise… maybe look to drop a cam in at the same time. We’ll see.
  • Hilly
    Hilly
    9 months
    Bobcat is a decent pipe on a 103", they sound alright as well, a bloke I knew put one on his 117" twin cam, wasn't enough pipe for it, somehow it was my fault! Lots of good cams out there for stock 103's, so much fun 😁
    9 months
    They are just so fkn loud for a tourer!
  • Hilly
    Hilly
    9 months
    Quoting paulybronco on 23 Feb 2025 10:19 AM
    If it's too loud ya too old.......young fucker said that to an old sparky on the way to work on the bus at Century as he had the music up full pelt, cracked me up.
    9 months
    Quoting Hilly on 23 Feb 2025 10:58 AM
    Thankfully my hearing is still pretty good but find the drone on cruise control gets me ringing ears after a few hrs.
  • evo94
    evo94
    8 months
    Quoting JFE on 21 Feb 2025 07:43 AM
    https://www.youtube.com/watch?v=gTYJnxlmYEQ
  • Hilly
    Hilly
    8 months
    Damn!
  • WideglidingNZ
    WideglidingNZ
    8 months
    Quoting evo94 on 10 Apr 2025 08:58 PM
    I wonder who will come to the party to pay for the engine rebuild, the dealer who fitted the pipe, the supplier or most likely the customer, personal i think the dealer should fix it then try and charge D&D apparently not the 1st pipe to do that
  • Hilly
    Hilly
    8 months
    There has been whispers, I had read it was from the internal coating peeling off the black ones, plain stainless or steel seems to be the safest bet presently.
