Online:
Can you add the Fuel level Sensor to a Sportster after the Digital speedo has married to the ECM?
GGUser644
1 year ago
Can I install the Fuel level Sensor (H-D part # 61200008A) after the Digital Speedo (H-D part # 70900100C) has married to the bikes ECM, and still have full "fuel related" functionality displayed from the speedo?
I saw a YouTube video where it stated that you only have 50km's before the speedo marries to the ECM and you can't add the fuel sensor after that, so I thought I'd see what you all have to say.
Thanks in advance.
OlChesnut
1 year ago
Yes you can. I've done it. My speedo/tach was married to the bike for much longer than 50km, and I added the fuel level sensor. I recall that in order to make the fuel level sensor start working I had to pull the main fuse then put it back in again. After that it worked.
