Online:
Hilly
Cleaning Roadworks Crud
Sniper
1 year ago
Recently had the misfortune of unavoidable roadworks on the RGST that horrible sandy road base junk, and to make matters worse they were wetting it down.
To say the sandy coloured crud has got in everywhere is an understatement.
So far, muck off, and snow job, had little effect.
I can scrub wheels, but there’s lots in very hard to access areas.
Has anyone found or recommend a cleaner that gets this shit off, but also not going to attack things?
Don’t really care what it costs…
Thanks
Rextheute2022
1 year ago
Try auto glym wheel cleaner ?
Spray on hose off - my heritage is a black finish and it cleaned all the Kurd off after a similar thing - cleaned the motor , painted bits under neath even the hard stuck on bugs .
I didn’t leave it on for too long , just as long as it takes to clean the wheels and then hosed off
Sniper and SRV72 like this post
SRV72
1 year ago
I'll give this a go. Thanks for the advice mate. My bike was covered in crap after a recent 8000km trip
WideglidingNZ
1 year ago
I highly recommend this stuff it works well, spray on let it soak then simply hose off-
https://motomuckproducts.com.au/products/automuck-clean-20-litre
