Online: beaglebasher
Taco WANTED to buy part number 67042-99
    1 year ago
    need desperately a taco of a 1999 to 2003 model  ,Dyna and Sportster all the same anything will do even if accident damaged as i need a diode from inside to repair mine or a good good replacement taco, any help would be great
  • obisteve
    obisteve
    1 year ago
    If you don't mind me asking, why do you suspect a diode is the problem? And is the diode not available from electronic retailers? I've got a disassembled 90 Sportster one that didn't like the end of the handle bar being hit with a big copper hammer while straightening out crash damage, and I've not got around to trying to troubleshoot its internals.
    1 year ago
    ive had this instrument tested properly  ,internal part is unattainable, bike is in good hands im a Harley workshop here ,
  • B0nes
    B0nes
    1 year ago
    Quoting daddyracer56 on 20 May 2024 11:59 AM
    Don't try Harley for the part. I used to build and repair electronics as a kid. Most are colour coded. Maybe send a pic to a place like this. https://www.diodes.com/
    Saved my arse a few times.
  • Pedro123
    Pedro123
    1 year ago
    You could try one of the electronic industry preferred suppliers, Farnell or RS.
    The diode will probably have some sort of identifier on it ( could be on the circuit board side when soldered in), so you might have to remove it to see the markings. Makes it easier to send pics if required anyway.
    1 year ago
    IN4007 or larger (IN4008 or 9) will do the trick.  Its just a diode....so pop down to JAYCAR.
    Have done this in the past to get a Tacho working.
