Online: John.R
Led indicator upgrade question
  • beehappier
    beehappier
    2 years ago
    Hi. I have a 98 fatboy and I upgraded to led indicators. It was all good for a while then I noticed the front indicators were scraping the fuel tank on full lock in the corners. So I decided to change the front led to mini led indicators. I fitted the first one and tested it and it doesn't flash, it just stays on. The current LEDs have fifteen LEDs in them and the new ones are minis only have three LEDs. Is it the different amount of LEDs throwing the flashing out? Thanks. Rick.
  • beaglebasher
    beaglebasher
    2 years ago
    I had the same problem with the blinkers hitting the tank so I loosened off the riser bolts and turned the bars up a bit. Just enough to clear the tank on full lock.
    I realised it was more comfortable than before and turned them up a bit more.
    Might be an option if you cant get the new ones to work.
  • beehappier
    beehappier
    2 years ago
    Thanks mate
  • Grease Monkey
    Grease Monkey
    2 years ago
    You might need a Badlands Load Equaliser mate, think you can get them local, eazyr or the like.
  • beehappier
    beehappier
    2 years ago
    It's got a load equaliser on it. It has been working fine for a couple of years. I put a new led indicator on the front and it's just staying on.
    Thanks mate.
  • Grease Monkey
    Grease Monkey
    2 years ago
    Maybe the flasher unit decided this was the time to cark it?
  • beehappier
    beehappier
    2 years ago
    The other three indicators still flash. I have only wired one of the small ones up so far. Cheers. Rick.
  • baldy1450
    baldy1450
    2 years ago
    got a load in balance connect up the others & it will work!
  • beehappier
    beehappier
    2 years ago
    Thanks mate. I will give that a go.
