Online:
tussuck, Hilly
Rocker rattle?
Rocker rattle?
RocketRodB
2 years ago
Hi, I have a 2023 Ultra and when reaching certain revs there is a rattle that sounds like a rock in a jam tine bouncing around. Been to the dealership with no result. This is really pissing me off with a brand new ride. Thought it could have been within the throttle housing/body as the throttle is a little weird in feeling. Thats is it is not smooth when starting to accelerate smooth as fell like its delayed. Any thoughts please?
Grease Monkey
2 years ago
Hey mate, dunno what you know about this stuff but that sound is usually associated with engine knock, sometimes called ping, has it had any mods or tuning done?
RocketRodB likes this post
2 years ago
Just take it back to the Stealership and lose your chit with them!. ask for a refund! that will light a fire under their sorry arses.
Grease Monkey and RocketRodB like this post
RocketRodB
2 years ago
Stock standard bike, no mods or tunes
Grease Monkey
2 years ago
Then as Tussuck said, you got to give them grief, general palm offs consist of, " they all do that"(they don't, or rather shouldn't) we can't replicate the issue! the fuck they can't, demand action bro, they proven they can't be trusted, treat them as such.
2 years ago
I've heard some noisy valve-train's om M8's .
It's an odd setup, two valves operated by one rocker arm, with no individual clearance adjustment ?
I did see S&S were selling adjustable rockers.
Grease Monkey
2 years ago
Quoting speedzter on 21 Oct 2023 09:00 AM
edited: 21 Oct 2023 09:01 AM
True that, Harley sell em too but if it is pinging time is of the essence, where ya at mate?
2 years ago
It's difficult, but can you explain the sound ?
Does it show up only on throttle roll on, or is it there on steady throttle ?
If you change down a gear to increase rev's when accelerating does it still show up ?
Any abnormal heat in the engine ?
Grease Monkey likes this post
GGUser616
1 year ago
It’s excessive end-float in the rockers. They tap on the alloy head casting. If you don’t get it early, the rocker end dents the alloy casting to the point where the FUELLING fix shims won’t sit flat. 23-on w
atercooled 117s and 121s are worst affected. Shim them back to 0.40mm or 1.8 thou on the affected side. Fixes them for good.
