Online: B0nes
Wheel spacers rear wheel on Fatboy
  • softfat
    softfat
    2 years ago
    Workshop manual and you tube clips all say rear wheel spacers are to be marked left/right which is understandable, but also marked with an arrow showing outward. Without measuring the spacers, the axle hole and circumference show/look exactly the same both ends. Is it that important on direction. I have marked the larger (belt side), but could not mark the smaller (ABS/disc) one as it was hidden with the wheel in place and fell out while removing the wheel. This is on a 2013 Fatboy. Thanks fella's for your help.
    Time for a new tyre as the old one was near the wear marks and was letting loose a little. Tyre was seven years old thanks to no riding through Covid.
    Soft...
  • Grease Monkey
    Grease Monkey
    2 years ago
    Hey Soft, howz it? Mines a 16, never noticed a difference with the little one.
  • softfat
    softfat
    2 years ago
    Going good there GM, and you buddy? That's good about the little one, as I said the bastard fell out as I moved the wheel. Any idea why with the big one it needs outside/inside direction?
    Soft...
  • Grease Monkey
    Grease Monkey
    2 years ago
    Going good mate thanks, honestly no, I've just always popped it back the way it came out, 3 times in total so far, the little bugga has fallen out each time, my first softail lol
  • obisteve
    obisteve
    2 years ago
    Could be a hangover from the tapered roller bearing with separate seals days, where the slightly rounded edge of the spacer went through the seal.
    I've got a mix of bearings on the Sportster, the converted Fatboy front wheel on the back has sealed bearings  the front spoked 21 has tapered rollers.
  • softfat
    softfat
    2 years ago
    Thanks GM and obisteve. All back (well almost) together. Slip on's to be fitted. The small (disc side) spacer, no wonder I couldn't see the prick before disassembly as it sat in the recess in the frame out of sight. Not really happy with the mob who fitted the tyre. Noticed a nick in the rim (chrome solids) which wasn't there before and the belt drive sprocket scratched. Lesson learnt.
    Soft...
  • Grease Monkey
    Grease Monkey
    2 years ago
    I put my axel in with the nut on the pipe side, have done it for many years, no issues and you don't have to pull pipes no more 😁
  • softfat
    softfat
    2 years ago
    Quoting Grease Monkey on 22 Oct 2023 10:19 AM
    Good advice GM. You can get the caliper off with your pipes in place?
    Soft...
  • Grease Monkey
    Grease Monkey
    2 years ago
    Quoting softfat on 22 Oct 2023 09:23 PMedited: 22 Oct 2023 09:27 PM
    Soft...
    Not sure about all pipes but i have with the 2 into 1 and fxst staggered exhaust, i can't remember if i did with the stock slim pipes which look like the stock Fatboy ones.
