Toe/Heel shifter FXDF
GGUser547
2 years ago
Hi everyone.
I've recently had an injury and it's caused me some dorsiflex (ankle) weakness and now find it very difficult to upshift in my 2014 FXDF Fatbob.
Does any know if it possible to get/install a heel shifter for my bike while keeping the stock forward controls??? Many thanks in advance.
Nikko, Perth
Grease Monkey
2 years ago
I can't see why not, the back lever will be hanging out in the breeze but it should work, you will need 16 and one 20 from the schematic, 16 has the longer shaft than what you have from memory (which means double check don't take my word for it) 😁
2 years ago
Something else to help would be a Baker N1 shift drum.
This puts neutral on the bottom , so much easier to select
Grease Monkey likes this post
