Online: beaglebasher
ABS flashing
  • P8ence
    P8ence
    2 years ago
    Just finished putting on mammoth wheels on a 2018 RK 21”front 18” rear. Had to get a 1/8” spacer for the front. However the ABS keeps flashing. Got no error codes. Thought maybe coz the spacer was between the bearing and sensor, so moved it to the outside of the sensor, however its still flashing and still no codes. Any ideas? Thnx
  • Grease Monkey
    Grease Monkey
    2 years ago
    Is an abs bearing in there?
  • P8ence
    P8ence
    2 years ago
    Supposed to be according to the order from DNA
  • Grease Monkey
    Grease Monkey
    2 years ago
    You could try disconnecting the battery for 20 seconds or so to see if it resets.
    Edit, have you ridden it?
    Also, are the rim sizes different to stock?
  • P8ence
    P8ence
    2 years ago
    Quoting Grease Monkey on 27 Sep 2023 10:51 AMedited: 27 Sep 2023 11:05 AM
    Yes have ridden it a few times   I’ll try the battery thing. And yes the wheels are different to stock. 21” front from 17” and 18” rear i think from 16 or 17”.  Cheers
  • Grease Monkey
    Grease Monkey
    2 years ago
    Quoting P8ence on 27 Sep 2023 11:24 AM
    It could be one of the ecms is not getting the signal it expects, IE wheel speed is different compared to what it was. I dunno for sure, never had the issue but you wouldn't be the first with this issue if that's the case.
