Online: Retroman, Ultramick
Front Fender Riser Bracket
  • Dalboy-Darwin
    Dalboy-Darwin
    2 years ago
    Anyone know where I can get a front fender riser bracket for a 2012 Dyna Super Glide Custom? Am changing the front wheel from 19" to 21". Can't find anything online. Cheers, Stay Upright!
    2 years ago
    Easy to make your own with basic hand tools .
    2 years ago
    I would have thought that any sort of riser kit would look horrid.  I would weld extensions onto the stock guard and repaint the end bits so its got the factory look.
  • Far Canal
    Far Canal
    2 years ago
    Quoting tussuck on 29 Jun 2023 05:28 AM
    That is exactly what I did on my FXST and it looks Ace.
    2 years ago
    Were only talking a 1 inch rise, it would be barely noticeable, as it's mostly hidden behind the forks.
  • Grease Monkey
    Grease Monkey
    2 years ago
    The softails are easy to do it to but the Dyna mounts are vertical so it's kinda awkward.
