WTB. Danny Gray Speed Cradle suit Rocker.
  • Rockerolla
    Rockerolla
    2 years ago
    As the heading says looking for a Danny Gray Speed Cradle to suit a Rocker C. Flame stitched, diamond stitched or plain. Weekday Solo second choice. Putting feelers out locally for a used one before looking international.
  • Baloffski
    Baloffski
    2 years ago
    Have had Danny Grey seat looking after my sorry old arse for ten years now, A course alternating between my solo seat.
    Has pump up, down- air hawks built in, one for rider one for passenger, and comfort has been good. And am surprised has lasted so long, then again same could be said of most of us. good luck with the Rocker, sure someone has one they didnt sell with their Rockon, are they a wide range of fitment, like does a Rocker one fit other model Harleys?
  • Rockerolla
    Rockerolla
    2 years ago
    Quoting Baloffski on 05 Jun 2023 02:20 AM
    You can fit a Softail seat if you have the Heartland conversion kit as it turns a Rocker into a normal Softail by adding a fixed fender and rear rails. A Rocker has a rear fender attached to the swing arm so the seat floats and can't be bolted to the fender. The seat is bolted to the frame. That's about the only difference.
