Online:
Hilly
Fork Seal Drivers
Fork Seal Drivers
408
2 years ago
I got a couple of these a while back; they were designed originally for working on dirt bikes but they will do the job on any bike and I had one made for the Fatbob.
https://www.ebay.com.au/sch/i.html?item=125890936857&rt=nc&_trksid=p2047675.m3561.l2562&_ssn=toranaz
They are good value and I got one each for 41mm, 43mm and 49 mm. I used one of the drivers over the weekend and they are the ducks guts.
I also got fork tube holders which I have not tried yet.
Nathan is a good guy and easy to deal with.
evo94, tussuck and Grease Monkey like this post
Grease Monkey
2 years ago
Good shit, I'm gunna need one in the near future
Grease Monkey
2 years ago
I contacted Nate, he gave me this link to a video of how it works, have a gander, nice tooling.
https://youtu.be/qQl7-f60vvs
Baloffski likes this post
Grease Monkey
2 years ago
408, mate, I gotta ask, for the love of god man, what fork oil are ya using .......
408
2 years ago
This was for my son's 07 dyna and he did his own research.
He ended up with Motul 10W.
Now as you know, HD generally recommends type E which is about 12W-15W.
So I told him we would see how it handles and may have to add a bit more than recommended quantity or swap in some 15W.
brucefxdl and Grease Monkey like this post
Grease Monkey
2 years ago
That can is full of bait 🤣
obisteve likes this post
brucefxdl
2 years ago
Quoting 408 on 01 Jun 2023 02:18 AM
edited: 01 Jun 2023 02:42 AM
resealed my dyna forks a while ago,didnt research well [ my blue ] and bought 10w fork oil,firmed up the front nicely,corners smoother now.front was a bit soft so no idea what was in it.the weep i had was very light so i dont reckon much , if any, was lost guessing the volume was
correct.new
oil was added by the book.
Grease Monkey
2 years ago
When you start messing around with forks using aftermarket stuff the oil weight and volume needed can be way different to stock, with my old wideglide I had a red hot crack sorting the front end, current bike has progressive struts in it, they work great two up but they are a little on the firm side, think I'm gunna have a crack at the pro action damper rod approach, no fancy valves or nitrogen chambers, a better mouse trap than the original damper rod design, see how we go.
brucefxdl likes this post
