Online: beaglebasher
96” works
  • Aussiesmiler
    Aussiesmiler
    2 years ago
    Hi all, have the old 07 fatty that I’ve stage 2 already and thinking maybe stage 3. Do you think boring to 107 and doing some head work is really worth it. Cheers
  • WideglidingNZ
    WideglidingNZ
    2 years ago
    hi mate it depends if you are happy spending the money, personally I think it's worth it, have a look at the attached dyno charts from Fuelmoto there are big bore 107's included-https://university.fuelmotousa.com/dyno-charts/ this should help you to find the right cam for where you want the power eg- low down torque or rev the needle to the redline power/hp
  • Aussiesmiler
    Aussiesmiler
    2 years ago
    Thanks for your information wideglidingNZ
    2 years ago
    OR..... one of those turbo units that bolts onto the primary side!  Now thats POWER.
  • Lushy
    Lushy
    2 years ago
    If your pipes are Big Radius , you will waste your money trying to get a good 107 to work.  If you are married to the pipes, then build a combo which is sound and make about 100hp at the tyre.
  • Aussiesmiler
    Aussiesmiler
    2 years ago
    Hey Lushy, no the old girl has had a few upgrades since the photo. Rinehart 2 into 1 S&S cams, intake oil plate & pump. Goes well just thinking of a bit more… of course! 🤙🏻
  • Grease Monkey
    Grease Monkey
    2 years ago
    Sounds like you understand the deal, as they say, no replacement for displacement, good heads helps along with the tune.
  • Lushy
    Lushy
    2 years ago
    No worries, which cams?
  • Aussiesmiler
    Aussiesmiler
    2 years ago
    S&S 583’s
  • crowster69
    crowster69
    2 years ago
    I took my old 88 cube out to 107 with s&s 585 cams and headwork and 45 mikuni.went very well
  • Aussiesmiler
    Aussiesmiler
    2 years ago
    Hey Hoodeng, not sure mate what’s your recommendation and thoughts on this, would prefer to only do things once of course. 🍻
  • Aussiesmiler
    Aussiesmiler
    2 years ago
    They’re recommending bore the standard cylinders to 107 and do some head work while doing the decomps. Other than that I haven’t discussed much as I don’t know a lot about it.
  • Aussiesmiler
    Aussiesmiler
    2 years ago
    I was told the S&S 583 would be a good mix for when the 107 works were done… would you disagree or what comp would you suggest with these cams. 🍻
  • John.R
    John.R
    2 years ago
    Quoting Aussiesmiler on 19 Apr 2023 08:33 AM
    Just plugging some of these knows in the a compression calculator, those cams on a 107 setup will have your compression pretty bloody high....  on stock flat tops with stock size HG you'll be at 211+ CCP
    You need to rethink this setup, or work with someone who can guide you holistically (obviously whoever your buying the parts from and who's doing the work)
  • Far Canal
    Far Canal
    2 years ago
    Also it is important to keep in mind who you are.
    Whatever you do there will be people who can ride much faster than you on lesser bikes.
  • Aussiesmiler
    Aussiesmiler
    2 years ago
    Quoting John.R on 19 Apr 2023 10:11 AM
    Thanks for the advice
  • Lushy
    Lushy
    2 years ago
    I have just fixed a job for a customer, which was done with a 107 kitted bike, 10.5 comp and these 583 cams. It had partially seized and was running like shyte. WAAY too much cylinder pressure. It was an unpleasant experience for both the owner and myself, costly as well.  As others have suggested the early  ( super early) inlet close figure means this cam is ok for  what you have now ie: getting good low end in a stock low comp 96 cube motor. I would respectfully suggest that whomever told you to use those cams in a 107 is not where you should be getting your next job done.
  • Aussiesmiler
    Aussiesmiler
    2 years ago
    Quoting Lushy on 20 Apr 2023 02:25 AM
    Interesting! Thanks for you response. Would you suggest just some head work with a good tune and not go the 107 or remove the cams before it’s all turns bad?
  • Grease Monkey
    Grease Monkey
    2 years ago
    You are in good hands with Hoody and Lushy mate, the big question here is how do you ride and what do you want from the engine? Answer that and they can guide you to your goal.
  • Lushy
    Lushy
    2 years ago
    Like GM asked, how do you ride, what do you want from the bike. If you are at 96 cubes,and want headwork, then you would need pistons, so the valve cutaways are good for larger valves, so I would select a piston (comp) and cam  to suit what you want, and go from there.. The one I just fixed, budget was an significant issue as he had already spent his money, so we changed the cam and valve springs, left the stock heads, but made them sound. You have options as you do not have to "rescue" anything.  How many kms has the motor done??
