Online: B0nes, Stuart, speedzter, Ultramick
Road Rage Long or not…
  • HOG63
    HOG63
    3 years ago
    Hi folks. Looking at options for Bassani Road Rage 2:1 exhaust system and can’t decide if I want the longer version (deeper note?) or the regular one.
    Can’t find any mention of performance differences.
    Up for opinions…
  • Jay-Dee
    Jay-Dee
    3 years ago
    My opinion is the shorter one looks better, but I expect the long version would likely be marginally quieter and possibly less annoying being a bit further behind you.
  • Streetbob10
    Streetbob10
    3 years ago
    The longer one will have slighter better performance then the short in my opinion and in my experience. Either way a quality performance exhaust
  • HOG63
    HOG63
    3 years ago
    Thanks guys. Seems like longer the better.
  • WideglidingNZ
    WideglidingNZ
    3 years ago
    hopefully they don't scrape as they look pretty low?
    3 years ago
    Quoting WideglidingNZ on 21 Feb 2023 11:07 PM
    They look REALLY low....  I mean the stock Screaming Begals on my 883L are scraped to heck and I recon they sit way higher than these ones.
  • HOG63
    HOG63
    3 years ago
    Hmm thanks guys - now I wonder if it’s a bad idea to get them.
    The hunt for a decent 2:1 continues…
  • HOG63
    HOG63
    3 years ago
    Found these on a Japanese website:
  • mykol
    mykol
    3 years ago
    Get a D&D exhaust 2 into 1 cost a bit more but sound really good quiet when they have to be but rowdy when you get into it i had one on my Wideglide get a bit better performance good clearance top quality
  • HOG63
    HOG63
    3 years ago
    Quoting mykol on 22 Feb 2023 10:52 AM
    Agreed. Look good and much better clearance. Thanks
  • Streetbob10
    Streetbob10
    3 years ago
    SUPERTRAPP FATSHOT 2-INTO-1 EXHAUST. If I was going 2-1. Looks and performance 👍
  • HOG63
    HOG63
    3 years ago
    Not this?
  • Grease Monkey
    Grease Monkey
    3 years ago
    I have a RushSuperLongShot......I think.....
  • Grease Monkey
    Grease Monkey
    3 years ago
  • WideglidingNZ
    WideglidingNZ
    3 years ago
    Quoting Grease Monkey on 23 Feb 2023 09:07 AM
    Hey GM so it looks like Rush use a plate baffle system like Supertrapp for the muffler judging from your picture is that correct?
  • Grease Monkey
    Grease Monkey
    3 years ago
    Quoting WideglidingNZ on 23 Feb 2023 04:24 PM
    Sorry mate I was just clowning around, the system on my bike is a hodge modge of parts from different manufacturers and a few self fabricated one off bits.
