"Rush"high performance racing exhausts systems
  • Uncle Chougs
    Uncle Chougs
    3 years ago
     Here’s something of interest if you are thinking about changing your pipes for more power and a better sound.
    Most riders are familiar with “Vance and Hines” but “Rush” Exhaust system not so much...They are made in the US by “Rush Racing Products” a quick search on the net will tell you a bit more about the company and what products and the technical features they offer.
    If you live in the Sydney area “Campbeltown motorcycles”(Macarthur region) has got the last stock and it’s going quite fast.They are new items and he sells them about half price of the retail price.
    If you are interested and to find out if he has what you’re after ,it’s probably best to visit the shop in Campbelltown or give him a buzz.
     He also sells them on Ebay :
    The top points of this system I’ve notice are;
    (the overview of the points explained are if your not familiar with high performance or not mechanicaly minded)
     They are ceramic coated,which improves performance but also looks good and lasts much longer than conventional coating.
     The dual pipes models are constructed with an exhaust balancer which helps to even out exhaust pulse and balance back pressure and creates more top end power.
    The exhaust baffles (and tips) are removable and can be swapped for quieter or louder tuned ones(not that you want the pipes to be loud LOL!!)
     They are very easy to fit.
      He does local pick up but he can also send them anywhere in OZ (I think around 40$ but best to check with him...)
