Fork extensions
  • Maca1
    Maca1
    3 years ago
    Has anyone used the 41mm HD 3" fork extensions I just don't get it they have a threaded hole right through the centre were the oil could leak do I need to plug them with a bolt or something  thanks
    3 years ago
    throw up a pic... I installed some lately and no issues what so ever.
  • T4
    T4
    3 years ago
    Air caps?
  • Maca1
    Maca1
    3 years ago
    Here is a photo i hope don't really know how to do it
    3 years ago
    Here are the ones I just fitted to the sporty.  The small hole in the top is simply a slot for a screwdriver or the like to help tighten the unit into the top of the fork tube - it is hidden by the top tree clamp once everything is bolted back up.  These ones are very solid.
  • Maca1
    Maca1
    3 years ago
    Yeah fitted them to my sporty to 39mm . But 41mm you can only buy the ones pictured with a hole througth the middle and threaded I don't get what the threaded hole is for
  • Uncle Chougs
    Uncle Chougs
    3 years ago
    Hey Maca,if you have the original 39mm triple clamps on your sporty the extensions won't fit as this "contraption" is designed to be fitted on some OEM 41mm set up(big twins) they slide into the recess of those smaller top triple tree fork diameter hole and gets bolted from the top clamp down.
    The center threaded hole is for the top cap.
  • Maca1
    Maca1
    3 years ago
    Thanks mate makes sense
