Cleaning Spokes
Cleaning Spokes
3 years ago
Has anyone a good way to clean the rough-cast grey area in the spokes? I want to paint that space Musou Black to see how it looks; but want things clean prior.
Grease Monkey
3 years ago
Sandblaster.......no I don't know, worst zinc plating ever, I rode 8 hours in the rain on a 2006 WG one night, shift work so didn't get back to it until the following evening, fucking spokes was covered in surface rust, pitiful for the price.
Grease Monkey
3 years ago
Sorry, your pic didn't load, there are some top notch mag cleaner stuff out there, some more aggressive than others, still can't help..
408
3 years ago
I reckon one of those home sandblasting kits would be the go. Mask up the polished stuff.
Grease Monkey likes this post
Far Canal
3 years ago
I'd reckon that a good going over with a stiff scrubbing brush and plenty of prepwash wax and grease remover would be all you would need to do, the cast surface is relatively rough so there is plenty for the paint to key into.
