Online: Stuart
Removing reflectors
  • WideglidingNZ
    WideglidingNZ
    3 years ago
    Hi I am thinking of removing the reflectors on my FXLRS which are on the rear guard and front forks, anyone done this before?
  • John.R
    John.R
    3 years ago
    Yeah did mine not long ago. Heatgun, fishing wire/floss/string etc, and wax and grease remover for any residue.
  • WideglidingNZ
    WideglidingNZ
    3 years ago
    awesome thanks John
  • bloodog
    bloodog
    3 years ago
    Quoting WideglidingNZ on 10 Nov 2022 05:10 PM
    Lovely looking bike WG
  • beaglebasher
    beaglebasher
    3 years ago
    Quoting John.R on 10 Nov 2022 08:22 PM
    A hammer and chisel is quicker.
  • WideglidingNZ
    WideglidingNZ
    3 years ago
    Quoting beaglebasher on 11 Nov 2022 05:16 AM
    a gas axe is quicker than that😜
  • Baloffski
    Baloffski
    3 years ago
    All the above. But let us not be carried away. or we could just utilise , Umm 'Det Cord' . Personally I flayed heat gun and fine wire, like fine wire, take  5 minutes max... Look they are there for a reason,,one being the Yanks have this thing like almost, Midgies, called I sue you if you can sue me.... Seriously.... Sorry lost the polt, just dont keep relfecting man, as umm no need. Keep well.
  • obisteve
    obisteve
    3 years ago
    I'm surprised that anyone here still has them on their bike.
  • Neale
    Neale
    3 years ago
    Hair dryer and thin fishing line worked for me.
    You’ll need a glove to wiggle it with the hair dryer blasting away on your fingernails. Once it’s moving just run the line behind it and wiggle it off.
    The fun police can nail you for taking them off though.
  • beaglebasher
    beaglebasher
    3 years ago
    My bike doesn't have reflectors. I'm thinking about buying some and attaching them to the bike just to be different.
    Where should I put them and how do you stick the fuckers on?
    3 years ago
    Quoting beaglebasher on 11 Nov 2022 11:26 PM
    JB weld is good for applying them.
  • Grease Monkey
    Grease Monkey
    3 years ago
    Quoting tussuck on 12 Nov 2022 12:19 AM
    If you can't get JB weld then liquid nails will get you outa the shit, bang a couple on ya helmet as well, can't be too safe these days
  • 408
    408
    3 years ago
    And just to be clear, anybody putting them on their helmets, it works the same as a box trailer;
    orange at the sides only , clear/plain at the front, and red at the rear.
  • Grease Monkey
    Grease Monkey
    3 years ago
    Lmao
  • Baloffski
    Baloffski
    3 years ago
    Ohh.... We came to this in such Clarity.. luvs ya all. Good work.  Sorry third bottlr.....
  • bloodog
    bloodog
    3 years ago
    Quoting Baloffski on 12 Nov 2022 08:03 AM
    I think yu spray cooking oil on the area of each side before attacking helps the look of the bike  in the long run
  • STEAMER
    STEAMER
    3 years ago
    Fishing line pull down behind reflector, then clean goo off with turps
  • WideglidingNZ
    WideglidingNZ
    3 years ago
    reflectors gone used a hair dryer and 24kg braid fishing line worked a treat thanks for the help
