Online: Soapbox2627
Crankcase venting
  • mykol
    mykol
    3 years ago
    I have had a look at this for my Streetglide 107 as my bike was manufactured 12/18 it has the old oil pump fitted ,Harley Davidson upgraded the oil pump on the late 2019 upto current models so from what i read is that if you fit this modification to a late 2019 or later model it will be fine but for the earlier models like mine it will puke oil out of breather mod , The upgraded oil pump in the later models is fitted with an oil seal against the crank bearing side and also modified 8 lobes on the return side of pump as compared with 10 lobes on previous models , So i have decided the best option for me is to fit a new camchest with high volume oil pump to fix the sumping problem with my model which pisses me off because i have already had a stage 2 fitted and if i had known this at the time i would have fitted it all at once
  • 408
    408
    3 years ago
    Not sure you need a new camchest. I believe you may be able to use a new cam cover with the seal .
  • Scouser
    Scouser
    3 years ago
    Quoting mykol on 24 Oct 2022 07:31 AM
    My Sport Glide is 12/18 as well so I cant fit it.
    Possibly might if I update the pump but apparently softails didn't suffer from sumping.
    Might just fit a DK Customs breather for the aircleaner as I get a bit through the cleaner
  • mykol
    mykol
    3 years ago
    Screaming Eagle is about the cheapest setup i can find S&S & Fueling are a fair bit more , when i ride the bike up around 3000 to 3500 RPM it spits a bit of oil from the air cleaner nothing major but enough to annoy me so i think by changing it out it will give me peace of mind and a bit more oil flow won,t hurt , next thing is to sort the suspension but that,s another story cheers
  • WideglidingNZ
    WideglidingNZ
    3 years ago
    hi guys I think people check their oil levels differently this is apparently the correct way, some people seem to over fill their bikes-  https://www.youtube.com/watch?v=thzjNfl95ro It's surprising the Screaming/Eagle stuff is cheaper than S&S or Fueling? from what I've heard the S/E stuff is pretty average especially their lifters & oil pump
  • Scouser
    Scouser
    3 years ago
    Quoting WideglidingNZ on 24 Oct 2022 11:22 PM
    When i first took mine home after picking it up
    I ended up taking nearly 1/2 a litre out…!
  • leyson
    leyson
    3 years ago
    The issue is the oil pump on the early models. Putting less oil in than recommended is just a backyarders way of fixing the problem.
  • Scouser
    Scouser
    3 years ago
    Quoting leyson on 28 Oct 2022 10:32 PM
    The dealer had put in too much
    I had to take it out to get to the correct level
