Online: softfat
Screaming Eagle oil, same oil into the 3 holes?
  • Firey
    Firey
    3 years ago
    I am thinking of buying a 2007 FXSTSSE series 11   CVO 110 Screaming eagle and he has been putting Screaming eagle oil into the motor, primary and trany since new, I thought you would need to run something thicker in the gearbox?  what you reckon -
    3 years ago
    I think you will find that Harley say you can run that piss thin chit in all three holes.
    Me, I ALWAYS run a 'real' tranny fluid in the gearbox - pick any brand tbh - for me its Redline Shockproof.
  • 408
    408
    3 years ago
    Harley call tenders and put their brand on the cheapest oil that meets their specs. There is always better.
  • Neale
    Neale
    3 years ago
    I remember watching on the idiot box years ago a bloke from the states who specialises in making his own gearboxes to suit hd’s, baker might have been his name, not 100 percent sure. Anyhow, his exact words were” Do not run engine oil in a gearbox, no matter what brand it is”
    I use Penrith 75/90 synthetic in my old twin cam, my sportster and M8.
    Never had a problem in using it for the last 12 yrs or so.
    The last oil change on my Electra glide with over 120,000 kms on it had no metal on the magnetic drain plug for the gearbox at all.
    3 years ago
    Quoting Neale on 07 Oct 2022 09:51 AM
    I use Penrith 75/90 .....
    Thought Penrith won the the footy grand final not make oil....lol
    Just taking the piss Neale know you mean Penrite.
  • Neale
    Neale
    3 years ago
    Auto correct I guess.
  • Jayman6
    Jayman6
    3 years ago
    Quoting tussuck on 07 Oct 2022 02:08 AM
    The mighty strawberry thickshake!
    3 years ago
    Quoting Jayman6 on 08 Oct 2022 12:39 AM
    +1
  • Scouser
    Scouser
    3 years ago
    Used Redline Shockproof in my Evo, never had a problem
    Also used Penrite Diesel in the engine, it loved it
