Online: Kato
Rotors/Discs
  • WideglidingNZ
    WideglidingNZ
    3 years ago
    Galfer and Lyndall are both good brands
    3 years ago
    Quoting WideglidingNZ on 19 Aug 2022 01:51 AM
    I run Lyndall pads on my Street Glide and they don't leave a ton of dust on the wheels or caliper. They do sound like a cicada when you jump hard on that front brake though.
  • B0nes
    B0nes
    3 years ago
    Quoting paulybronco on 19 Aug 2022 07:51 AM
    + 1 on the Lyndall Pads. Been using them for a few years and just picked up a set for the Night Train and a set for the Ultra.
    3 years ago
    Arlen ness is poser chit (may as well install kuryakyn) .... At least PM are a performance brand.  What about OEM Harley options?
  • WideglidingNZ
    WideglidingNZ
    3 years ago
    These 2 brands are disc rotor suppliers? and are from USA, Lyndal not only make pads
    3 years ago
    Quoting tussuck on 20 Aug 2022 12:34 AMedited: 20 Aug 2022 12:35 AM
    Generally OEM equipment is bought/manufactured for a component price where price overrules quality/longevity. Aftermarket mostly is a upgrade to OEM but could be more expensive due to low volume and good quality.
  • Grease Monkey
    Grease Monkey
    3 years ago
    Dunno what's on yours Wombat but on 2016 FLSS it has floaters front and back, stock pads, if it didn't have abs a handful of front brake would result in nose to road, Harley brakes used to be iffy, that's not the case these days, in my experience anyways, possibly had to lift their game in the land of litigation.
  • Grease Monkey
    Grease Monkey
    3 years ago
    I guess what I'm saying is if you need rotors don't discount the later HD stuff based on the old.
    3 years ago
    Quoting Grease Monkey on 20 Aug 2022 11:34 PM
    A change to Brembo has been the savior for Hd compared to the crap used before.
    3 years ago
    Custom Chrome Catalogue might have a good range of brands etc that you could window shop.
  • Grease Monkey
    Grease Monkey
    3 years ago
    Big them eagles, a mate shared the cab of his LandCruiser ute with a wedgy one fine evening in the Gascoyne, didn't recommend it.
    What you have got will get you by for sure.
