Online: Stuart
Freedom performance outlaw exhaust
  • evo94
    evo94
    3 years ago
    faaark ...1750?!? :-/
    3 years ago
    Fark, $1700 for a set of pipes that look bloody average .... thats insanity
  • John.R
    John.R
    3 years ago
    You boomers haven't kept up with price of pipes lately have ya?
  • 408
    408
    3 years ago
    Quoting tussuck on 07 May 2022 10:59 PM
    The key word here is 'performance', something you never seem to worry about.
    I believe these pipes have the triple stepped header and two step baffle.
    Postie
    Stick with the black ; chrome heat shields would not look anywhere near as good on that bike.
    I would be shopping with EasyR for that stuff, I have found Rollies are shit at standing behind their products.
    A good heat resistant paint should be adequate for the heat shields. How is your tune ? What is the paint like on the headers ?
  • 408
    408
    3 years ago
    Exhaust wrap looks pretty good. I have considered it in the past. There are pros and cons.
    I have seen reports of pipe corrosion due to trapped moisture. I wouldn't risk it with the dollars you have in those pipes.
    Do a bit of research before you commit.
  • Grease Monkey
    Grease Monkey
    3 years ago
    Heat shields you could get powder coated with a high heat tolerance product, won't cost stuff all either, not a fan of the wrap look but it's not my bike so that's a moot comment I guess.
  • Grease Monkey
    Grease Monkey
    3 years ago
    That's mine after I finished chopping it up, powder coated with high heat stuff, think it cost $160 for the whole lot to be done.
    3 years ago
    Quoting John.R on 08 May 2022 12:04 AM
    I just make my own!
  • Jay-Dee
    Jay-Dee
    3 years ago
    Black ceramic coating, it's more expensive but the bike looks too good not to.
