Online: Stuart
Just bought a 2009 rocker c and was told it might have a cam, can you tell from this Dyno chart?
  • RockerC0911
    RockerC0911
    3 years ago
    2009 fxcwc
    VH sideshots
    Kuriyakin hypercharger
    SE super tuner pro
    Ok.... so I was told the first owner put a cam in it, i don't know if they did or not or what cam it might be, any idea's from the dyno chart?
    3 years ago
    Seems like its turned the power upside down....
  • steelo
    steelo
    3 years ago
    Welcome to the forum. I turned your photo up the right way
    BTLOI on a couple of sites. The 2009 Rocker C has a 1584
    Standard Hp = 68,  Yours = 77.45, Dif = 9.45
    Torque 86.3Ft/lbs @ 3200rpm, Yours = 92.47, Dif = 6.17
    I'd "say" it's likely you have a cam. Air cleaner and exhaust may give you some. A good tune may add a small bit.
    We do have some specialist tuners on the site who may be able to give you a better idea
    Edit. Don't bandy about too much that you have a Hypercharger. That's like saying you have a small dick. Something to be laughed at. (not me of course) I've had to live with the shame of only having a 12 inch penis. I don't get to use it as a rule
    3 years ago
    It’s likely to have a cam. I think those numbers that steelo posted are at the crank whereas that dyno is at the wheel. A stock cam starts with more torque and falls away. Your bike will go better if you put a decent air cleaner and exhaust on it.
  • RockerC0911
    RockerC0911
    3 years ago
    Hahaha cheers for flipping the pic and the info, and whats wrong with H/chargers?? Ive had 4 harleys and this ones the first one ive had with butterflies, fkn love it!  Givin me butterflies even..
    That being said most hp chasers have a 2 into 1 exhaust and i couldnt deface a bike like that lol
  • RockerC0911
    RockerC0911
    3 years ago
    Quoting fatbat on 24 Apr 2022 10:07 AM
    Cheers, im used to having hd heavy breathers and drag pipes, this ones a lot quieter than my 2011 was but the power seems very similar,maybe more tq
  • Grease Monkey
    Grease Monkey
    3 years ago
    Might be SE204, HP is the right shape
  • bloodog
    bloodog
    3 years ago
    Nice looking Rocker chuck up a few picks
  • Grease Monkey
    Grease Monkey
    3 years ago
    Pop the cam cover off, easy to do with that exhaust, most cams have what they are stamped on the end, if you want to know what tune is in it you can download the SE software from the internet, plug the dongle into bike and computer, retrieve calibration from dongle, open and compare with its corresponding number from the Cal bank, then you will know if it's been tuned or altered in any way.
  • RockerC0911
    RockerC0911
    3 years ago
    Quoting Grease Monkey on 24 Apr 2022 09:34 PM
    Thankyou, thats very good advice, i was hoping there would be software trail. I dont like taking tools to my bikes without good reason, makes them somehow feel a lot more used haha
  • RockerC0911
    RockerC0911
    3 years ago
    Quoting bloodog on 24 Apr 2022 07:05 PM
    Thanks mate, heres a few, i changed the pegs and did away with front indicators using the led side mirror type. Theres a few more thing i want to do like change the rear indicators.
    I included a pic of my 2011 rocker that was recently lost to the floods and why im starting fresh with the 09
  • RockerC0911
    RockerC0911
    3 years ago
    Quoting Grease Monkey on 24 Apr 2022 03:25 PM
    Thanks, i think i get a bit more out of the gears with a bit more low end power than i used to with my last bike, i assume the dyno tune unlocks the rev range on these to 6200rpm?
    Its always annoying with secondhand bike trying to work out whats been done to them
  • Grease Monkey
    Grease Monkey
    3 years ago
    If it's been tuned on a dyno the bike mods could be listed in the comments in the calibration, you good with sort of stuff or not so sure what's what? Only asking as I don't want to tell you how to suck eggs.
  • RockerC0911
    RockerC0911
    3 years ago
    Quoting Grease Monkey on 25 Apr 2022 10:01 AM
    Never done it but im sure i can work it out, ill get hold of the cords the tuner needs and get back to you, cheers!
  • Baloffski
    Baloffski
    3 years ago
    Likewise thanks GM.
  • RockerC0911
    RockerC0911
    3 years ago
    Just waiting on my $4 cable to arrive and ill give an update 🤟
  • Lushy
    Lushy
    3 years ago
    77hp,  a good stock 96cube does about that. Those old V&H pipes are actually surprisingly good.
