Online:
tussuck, Ultramick
96ci to 103ci
96ci to 103ci
Sed8td
3 years ago
Back again with a new set of questions, since I've fixed my "fouling plugs" questions.
I have a 2011 Softail standard 96ci with se259 cams, springs and heavier clutch spring.
To me the cams are only useful up high, would dropping some 103 pistons and jugs make it pull more down lower?
Which leads to my next question, I'm good on tools and handy around cars, but is it a easy job to swap jugs and pistonor best to let a shop handle it?
Also, the jugs I'm looking at are black and mine is standard alloy colour, can the black ones be painted and actually look good and last with the heat these Harleys produce?
Far Canal
3 years ago
Quoting Sed8td on 31 Mar 2022 11:11 PM
I put the 103 jugs on my 96 when I had the stage 4 upgrade. The jugs that were available to me at the time were also black and I had the shop paint em the standard silver colour and bake em in an oven. They have lasted pretty well.
Sed8td likes this post
Grease Monkey
3 years ago
Those cams need a bit of compression to be good down low, 10.5 is a common set up, you could put a set of cams in it more suited to the 96", just chucking it in there, if you have a manual and are handy with the tools they are just nuts n bolts.
Sed8td
3 years ago
Been chatting to a few guys, I'm now thinking of getting higher compression pistons and going 107ci to suit this cam.
Soapbox2627
3 years ago
I had my 88 built to a 103 when I done a cam bearing, amazing performance, still going strong
