Online:
beaglebasher
Stage 1 2017 Sportster | Tune to Different States?
RodFortyEight
3 years ago
Hi All,
Trying to cut through some BS from a few different sources.
I bought a bike from QLD - Stage 1 Sportster with SE tuner.
Will the tune be different between states?
I get how altitude obviously affects it but the change from QLD to NSW seems far fetched.
Thanks in advance.
Soapbox2627
3 years ago
sea level (funny enough) is the say in all states, I'd call bullshit
RodFortyEight likes this post
steelo
3 years ago
What if it was tuned at high or low tide in Qld? Would that make a difference?
tussuck, paulybronco and RodFortyEight like this post
3 years ago
Quoting steelo on 25 Mar 2022 10:26 AM
Only if it was insured by Club Marine perhaps....
3 years ago
Quoting RodFortyEight on 25 Mar 2022 08:04 AM
Hi All,
Thanks in advance.
Its all good Rod .....pay me $500 and i can sort it for you, you wont even know i have changed a thing.
Grease Monkey
3 years ago
It'll be fine mate, most likely just a stage one flash anyway.
Soapbox2627
3 years ago
the real answer is if it was tuned in one state, and then a tour of the country, there is no need to re-tune as you go, have a good ride
brucefxdl likes this post
Grease Monkey
3 years ago
If you want to know what cal is in the bike, download the software from the net, hook up the VCI to bike and computer, open the program, turn the bike on but don't start it, download the calibration that is stored in the VCI, find the same calibration in the Cal bank, open both cals and compare them to see if any tuning was done or not, I'd bet not, if none of the above makes any sense then don't do it :)
3 years ago
Finding the last update of Screamin' Eagle Supertuner Pro software may be difficult now.
No longer "supported" by HD. I do believe it can be found tho'.
Your Stage 1 tune will be the same as the world wide version most likely.
Chance of a Sportster being "Dyno tuned" is rare I would have thought, it's rare enough on the Big Twins.
