Online:
beaglebasher
Twin cam 103 cam bearing tools
Trotts
3 years ago
Hi guys and thanks for the add to your forum.
Hate my first post to be looking for something but here goes.
I recently purchased a set of bearing pullers/replacers for my 2016 Road King. Putting in a set of Wood 222s.
Anyway, the tools they sent suited the early model not the 103. I am now half way through the job unable to proceed. They cannot provide the correct size. Others have to come from the other side of the world.
My question is does anyone have a set of these tools they would like to sell or rent to me so I can finish the job.
Thanks
Richard
robots
3 years ago
What suburb
Trotts
3 years ago
Toogoolawah
Richard
markwoumla
3 years ago
Hopefully someone north of Brisbane has the cam bearing tool for your bike ,and will let you have it for a day or two...
Meet up half way in you car.... Or,, if you were going to get the bike tuned , (dyno), in the Brisbane area, the shop may loan you the tools to get you sorted, just a thought...
By the way,, good choice in the new cam your putting in.....
Trotts likes this post
robots
3 years ago
any action with getting tool
Trotts
3 years ago
Nope. No replies sadly. For most of us they would be a once or twice use item then move them on. Iโm thinking of alternatives.
robots
3 years ago
ok, i am in Vic. will send you message
tussuck likes this post
Trotts
3 years ago
Big thanks to Robots for a inner cam bearing tool. Tomorrow Iโll pull the bearings and replace, then put the new cams in. Looking forward to having her back together. I will report on the TW222 cams.
tussuck and Grease Monkey like this post
Trotts
3 years ago
TW222s Installed. Very happy with the result. Nice torque and power. Very smooth delivery. Recommended. FP3 canned map seems to be working nicely. Had a couple of issues with loosening pushrods. Lock nut issue. S&S adjustables(that I got) lock to the bottom adjuster not the top. ๐ณ๐ณ. Should have looked more closely at what I had not YouTube. Alls well that ends well๐๐
markwoumla
3 years ago
Are,, the old lock the lock nut to the top trick,,,,, You wont be doing that again !!!!!!!
Good to hear your happy with the tw222's..... The FP3 does not seem to be the flavor of the month with tuners ,, but a good canned map is a good canned map to get you going..... Plus the ease of downloading via the mobile phone,,,(especially it you have the tuner with the bike......
Also a shout goes out to Robots for the cam bearing tool ....
Cheers.....Mark
Trotts
3 years ago
Yes if I had looked at them more closely before hurrying to get them in I would have noticed. But no. My RK had a couple of nice trips home in the trailer. Even old fools can learn. ๐
