Online:
Stuart
Oil change query TC 1450
Kato
3 years ago
Hi
Can anyone shed light regarding the following
1. the sump plug (well i assume it is as shown in the photo below ) and why HD don't say to remove this plug in lieu of the oil tank drain plug one ??. It would appear you would get a LOT more oil out of the sump plug V's the oil tank drain plug
2. do you drain the engine oil hot or cold
3. Has anyone had a twin cam crack sat 130,000 kms
The engines done 90,000 Kms and still goes well and perhaps (hope) that has had something to do with oil changes at 4,000 Km intervals
I'd really appreciate any advice
Anyway - Have a Winfield (that's still a great commercial with Paul Hogan in it when life was a lot simpler)
03 Anniv . 90,000 Kms
The sump plug in question
Soapbox2627
3 years ago
My 04 Nightrain, I have a vague memory that the sump plug was over on the side, with a do not remove on the middle plug, but I could be wrong
John.R
3 years ago
1. That crankcase plug would only drain any residual oil sitting in your crankcase. Thats not where your oil is stored, which is the oil tank.
2. Warm is best as it'll be quicker.
3. Heaps of people, particularly early twincams with timken bottom ends. That stopped in 02 though.
Kato
3 years ago
Thanks for your advice . Much appreciated
