110 twin cam upgrade
  • Gibblys2016HD
    Gibblys2016HD
    4 years ago
    Hi guys ive just joined the group
    A while back i brought a set of barrels and pistons out of an 2017 FATBOY S 110 cube , i intended fitting to my breakout. but have brought a 2015 street glide so am thinking of fitting to this
    can anyone tell me if they will fit ?
    I assumed with SE bolt on 110 kits it would work
    Any help would be great
  • John.R
    John.R
    4 years ago
    If they're off the factory 110, they wont fit your motor without machining the cases.
    The 'Drop in' 110 kit has a super thin spigot area to allow them actually fit standard cases without machining larger.
  • STROPP
    STROPP
    4 years ago
    I have heard of a mechanic in Richardsons hd machining the spigot to fit but I would be cautious about doing that.
    4 years ago
    Quoting STROPP on 21 Feb 2022 01:49 PM
    Agree, i believe the factory bolt on kit has a totally different liner made from a material that allows it to be thinner yet just as strong and warp resistant as the std 110 barrel. As John mentioned its a case machine job to get the std 110 to fit.
  • Gibblys2016HD
    Gibblys2016HD
    4 years ago
    thank for the input guys looks like i have parts for sale lol
