Interesting Shovelhead?
    4 years ago
    Where did you get this from and what’s the plan with it? John Trease stuff would be pretty rare now
  • John.R
    John.R
    4 years ago
    It was a bike (or bunch of parts) that was lined up and on the list to be built by TRE, but didnt make it.
    I reckon I'll sell it. I thought it came with heads, but unfortunately, didn't (or the heads it came with are DEFINITELY not for this). Also thought it was an Evo setup, but turned out to be a shovel, which I dont really muck around with.
    4 years ago
    That's a really unique motor......never heard of a piston without a gudgeon, how does that work?
  • John.R
    John.R
    4 years ago
    Quoting paulybronco on 10 Feb 2022 09:23 AM
    Aluminium or Teflon buttons that essentially rub the cylinder wall.
    The reliefs cut into the pistons are pretty wild too.
  • FBUser214
    FBUser214
    4 years ago
    Quote source removed.
    You got that from Ranelagh ?
    4 years ago
    Quoting John.R on 10 Feb 2022 11:37 AM
    Wow interesting design......thought i had seen it all after holding a NR750 oval piston with twin rods and 8 valves per piston.
  • John.R
    John.R
    4 years ago
    Quoting FBUser214 on 10 Feb 2022 12:00 PM
    I don't know what that is.
  • John.R
    John.R
    4 years ago
    Quoting paulybronco on 10 Feb 2022 12:06 PM
    Sorry I re read what I wrote. It has gudgeon pins but not the actual CLIPS or spiral lock setup. It just uses those buttons to fill out the extra space.
    4 years ago
    Teflon buttons are common.
    4 years ago
    Quoting John.R on 10 Feb 2022 12:20 PM
    LOL that makes a little more sense.
  • John.R
    John.R
    4 years ago
    A little.. not much more to me though haha. Why not just run clips?
    4 years ago
    Quoting John.R on 11 Feb 2022 12:19 AM
    Guessing its a point of difference along with the zero risk of the clip coming adrift and scoring the bore.
    4 years ago
    Quoting paulybronco on 11 Feb 2022 12:29 AM
    I think they are VERY common in Drag engines as there is way less risk of dropping a circlip into the sump.  Esp when fast engine build turnaround is critical.
  • John.R
    John.R
    4 years ago
    Quoting tussuck on 11 Feb 2022 12:54 AM
    That makes a lot of sense.
    I like seeing all of this stuff, but its above my paygrade for sure.
    4 years ago
    Quoting John.R on 11 Feb 2022 10:58 AM
    Umm thinking your selling yourself a bit short there young man...
