110 barrels onto 96
  • Cogie11
    Cogie11
    4 years ago
    Gday fellas I’m looking at a doing a big bore kit on my 96inch 2010 backline. A friend has a brand new Harley stock 110inch barrels, pistons and all the bits left over from when he took his to 117inch. Will stock 110inch barrels fit my bottom end with out machining?
  • FBUser214
    FBUser214
    4 years ago
    No.  The drop-in 110 cylinders use a different material for the liner to enable use of a thinner sleeve. Stock 110 cylinders will not work without machining the cases.
  • Cogie11
    Cogie11
    4 years ago
    Cheers buddy
