Online: Humbug
Dyna won`t idle after filter clean
  • gidgi
    gidgi
    4 years ago
    Something I`ve done a thousand times clean & oil air filter ,same ol K&N recharge kit, a couple days later  went to go for a quick putt & she stalls every corner the bike is a EFI dyna so if a piece of crap has gotten into throttle body where would I look first, strange thing is if I manually hold the throttle open at low speed there`s no missfier & idles good, it just seems a big coincidence the idle screw needs adjusting all of a sudden. maybe that`s all it is.??.  I will have another more intensive look when it cools down any ideas ?
  • Soapbox2627
    Soapbox2627
    4 years ago
    I would check all is aligned, square and tight, no air leaks
    4 years ago
    I would just rip it apart again looking at the components as i did so.  You will most likely see something out of place causing the issue.
  • brucefxdl
    brucefxdl
    4 years ago
    Quoting gidgi on 03 Jan 2022 02:19 AM
    reckon your idle air control [ iac ] is playing up/sticking,my efi dyna does it sometimes,out of the blue as well,i clean the iac port [ very small at 12'oclock on the throttle body] with spray throttle body cleaner and cycle the key on/off a few times while spraying [ gentle amounts]seems to work for me...i'm too lousy to invest in a new iac. note ,put rags around/under the intake as shit will dribble down on cases ect.hope this helps.
    4 years ago
    Quoting brucefxdl on 03 Jan 2022 02:55 AM
    This….
  • gidgi
    gidgi
    4 years ago
    Brucefxdl recon you are spot on mate you are a superstar, ripped it down took of backing plate cleaned out plugs & iac thingy ,Rewashed out oil off filter, (I just thought it may have been over done )  will give it a  light oil later ,adjusted the slack in throttle cables, good as ! cheers mate for taking the time to answer ,also all who responded, great site! been helpful many times over the 12 odd years Ive been here.
  • brucefxdl
    brucefxdl
    4 years ago
    Quoting gidgi on 03 Jan 2022 05:17 AM
    no worries,i learn ,i share.i used to just spray and wipe and it would be ok for a while..then read someones bit about key cycles some where ,that bit helped heaps.glad you got it sorted.cheers.
