Online: B0nes, Stuart, speedzter, Ultramick
Primary Case drain plug - 2003 1450 Fatboy
  • Kato
    Kato
    4 years ago
    Hi
    Just a FYI for everyones comment or notice as they see fit
    I got a slight leak on my primary drive and started wondering why
    When you remove the Primary Drive drain plug you will note
    - there's no O ring ????? (to create a seal)
    - There is no torque setting when you reinstall it ????
    There's no Torque setting as the plug cannot have one ( If yoyu keep screwing it up into the Primary Case it will "fall into" the case - well it sure seems that way to me )
    HD factory manual says  to screw it back into the case  with 4 mm left exposed below the cover ??
    So you need some kind of sealant placed onto the thread to create a seal so the drain plug wont leak (well in my view you do and White plumbers tape it hopeless)
    i have opted  for Permatex high performance thread seal $25-00 and withstands pressures up to 10,000 PSI etc etc
    Anyone experienced this problem with their Primary Drives ( All primary drain plugs have a O Ring installed from 2005 onwards i think and its a MUCH better set up i think )
  • Far Canal
    Far Canal
    4 years ago
    Well that drain plug set up looks dodgy A.F!.
    If it were my bike I would see if one of the later type plugs with o-ring (or a suitable soft metal washer) and hex fasteners will fit.
  • Kato
    Kato
    4 years ago
    As dodgy AF as it is - thats a factory drain plug on the primary
    Its in all HD bikes that have this engine (until the drain plug is / was updated to a O ring style)
    You CANNOT just fit a O Ring to that drain plug ( its not machined to take it )
    The Dealerships just replace the drain plug each time the oils changed ( what that stops i will never know )
  • Old Fatty
    Old Fatty
    4 years ago
    I've got an 02 Fatboy with the same plug. First time I changed the primary oil it leaked like a sieve, so I pulled it out and wrapped teflon tape around it. Never had a problem since.
  • Baloffski
    Baloffski
    4 years ago
    That's a course pitch thread on the plug, wonder if that's a factor of leaking. Anyway, no issue on 06 Fattie, as you said K changes made. Sometimes the simplest fix is the easiest, if not the answer,  old fatty's.
  • Pedro123
    Pedro123
    4 years ago
    Have just finished servicing my 2016 model and even with the machined plug and o ring the manual says to use a thread locker on it.
  • beaglebasher
    beaglebasher
    4 years ago
    I have had the primary cover off three times in the past year to fix a leak. Three new gaskets at $50 odd a pop just quietly.
    The last time I did it I used the Permatex aviation gasket maker ( as well as a new gasket ) and I was pretty sure that would fix it.
    Until last week when I noticed another oil stain on the concrete. I wont subject everyone to the foul language I used when I saw it.
    I never gave the plug a thought until Kato mentioned it. (same type of plug ) I had a few beers under my belt by the time I screwed the plug back in and filled it.
    I have gave it a good wipe and I will have a closer look to see exactly where its coming from.
  • John.R
    John.R
    4 years ago
    Pretty sure those plugs are tapered thread, not regular. If it's threading all the way in and past, somethings fucked already.
  • Kato
    Kato
    4 years ago
    John R - I can assure you the drain plug is NOT a tapered thread variety
    Beagle Basher - quietly confident it wont be the P Cover gasket . Have a look directly plumb up from where its leaking and youll find its the drain plug and it leaks "along" the case as well . Cannot believe HD dont have a O ring on their drain plug i must say on this model
  • beaglebasher
    beaglebasher
    4 years ago
    My plug is different from yours Kato. Pretty sure it would be 1/8' NPTT   ( National Pipe Thread Tapered )  Mine takes a Torque driver to remove. ( a 3/16" Allen key if you are desperate but I would avoid that)
    The original leak on mine was because the capscrews came loose on the case . When I took it off there was a noticeable  lip / ridge on the case where it would have been vibrating against the motor but I thought the new gasket should take it up but it didnt so I done the job again and filed the lip off and put it back together with a new gasket. Still fukin leaked !
    So I done the job for the third time with a new gasket and Permatex.  Looks like it might still be fukin leaking.
    I hope it is the plug cos I cant be fucked taking the case off again.
  • Baloffski
    Baloffski
    4 years ago
    So Kato, what do you do to rectify? Is the drain thread able to accept a later model 'o ring drain bolt', or is it recessed slightly to take the o? No machinest but there must be a reasonable simple fix.
    As you say is fucked up design, and they beat the Japs, how long is this drain plug been in HD  models?
  • John.R
    John.R
    4 years ago
    Quoting Kato on 20 Dec 2021 07:46 AM
    "John R - I can assure you the drain plug is NOT a tapered thread variety"
    What level of assurance?
    Because its 1/8th -27 NPT stock... so not sure what's going with yours for you to be sure its not a tapered thread (well, doesnt sound like its tapered anymore anyway)
    4 years ago
    Quoting beaglebasher on 20 Dec 2021 06:55 AM
    Could also be the clutch shaft bearing support on the inner side of the primary as well.  Can be a real bastard to get to and diagnose.
    4 years ago
    Harley part number 739 or 739A Transmission Drain Plug 1/8"-27 NPT.  I have the 739 in my old bike and you should always use a sealant with them as they will always leak given half a chance.
  • Kato
    Kato
    4 years ago
    My 03 has the 739A Transmission drain plug . Sealant is a must as you have mentioned . Some say plumbers thread tape - thats for cold water plumbing not a hot engine . Thats why i have been using Permatex High Performance Thread Seal
    Cannot fix it other than use Permatex as stated above in my view . Drain plugs been in for years but from 06 ( as far as i know) its been changed to have a O ring on the drain plug
    Its not tapered as you would be able to see that in the drain plug and it will "take up" when you screw the drain plug into the case . If you keep screwing a tapered thread into the case it will most likely crack the casing
  • John.R
    John.R
    4 years ago
    Mate, Look up what exactly PN 739A is... or what NPT is. While it might not be obvious to the naked eye because its a tiny and short thread, its tapered. If you want to get technical, the taper is just under 1.8 degrees...
    If it wasn't tapered, that PN would be NPS, which is the straight and NOT tapered thread.
    Why are you so adamant its not? Because you cant see it with your naked eye? Run a micrometer over a new plug and see?
  • Kato
    Kato
    4 years ago
    Quoting John.R on 20 Dec 2021 10:41 PMedited: 20 Dec 2021 10:47 PM
    Nice .........real nice .
    Ive only put this advice (and my time to assist people for the joy of assisting people) -
    You can measure all you like with a Micrometer
    as far as i am concerned ............. bloody hell
  • evo94
    evo94
    4 years ago
    lol...not gonna change his mind John
  • FBUser214
    FBUser214
    4 years ago
    Tried plumber's tape once , seemed like a good idea at the time, then I read reports of it partly dissolving in oil and petrol.
    I now use CB 7567 pipe sealant, good for sump plugs and petcocks, and it is not going to end up in oil filters , lifters, or fuel filters.
  • John.R
    John.R
    4 years ago
