Revo A spacers
  • binnsy
    binnsy
    4 years ago
    Chasing a set of spacers to suit Revo a shocks on a Street Glide Special.  Its an odd part to buy and looking like only available from the states. $135 to get them here for a few washers !!!
    Wondering if anyone on here may have some somewhere .
    Seems my purchase of near new Revos arrived minus the spacers needed to fit them properly.
    Could have a set made on a lathe if anyone has any idea of the sizes?
  • brucefxdl
    brucefxdl
    4 years ago
    once you get the sizes,you get them machined out of stainless.
  • binnsy
    binnsy
    4 years ago
    Quoting brucefxdl on 17 Dec 2021 06:06 AM
    Thanks mate.
    Hoping someone chimes in with the sizes of them.
  • gidgi
    gidgi
    4 years ago
    Quoting binnsy on 16 Dec 2021 11:35 AMedited: 16 Dec 2021 08:04 PM
    G`day binnsy I have some pics for you mate The darker washers are the REVO 4 in total lighter ones are OEM I hope the measurements are accurate enough & fitting diagram showing where the  new washers are to be fitted  Hope this helps, also a pic of the part number of these particular shocks for you to compare for your bike cheers bud
  • binnsy
    binnsy
    4 years ago
    Thanks gidgi.
    Exactly what I was after. Great stuff. Big help.
