Sagging saddle bags
Sagging saddle bags
Tasslehoff
4 years ago
I’m currently designing a set of brackets to use to support and reinforce the sagging saddle bag issue I see around a lot. I’m about to finalise the design and want to sell them.
These will be sold as a pair and made from 3mm Galvanised steel and power coated black. Simple 10min install with this current design.
Modelled off my 2014 Heritage softail classic.
Curious on your thoughts.
Before
After
GGUser260 and STEAMER like this post
binnsy
4 years ago
Doesn't affect me but excellent job I reckon, well done.
GGUser260 likes this post
STEAMER
4 years ago
Have actually seen kits that flat 3mm plate is bent in a big U and holds bags in shape
Far Canal
4 years ago
Hi Tassiehoff, you might be onto a winner there but your pictures do not explain whatever it is you are aiming at.
T4
4 years ago
My solution, which has lasted for thousands of kms.
2mm plate, all home brewed. This on my Triumph, but the ones on the Harley are similar.
Cheers, Will
Mount plate
Inside view
