Tyre valve size?
Tyre valve size?
Tags
4 years ago
Hi all, just trying to find out what the size of the tyre valves are on a 2019 streetglide as I am replacing my tyre and want to fit the right angled valves as its much easier to inflate tyres with them, I have seen 11.3mm and 8mm sizes online, mine are just the standard rubber valves no pressure monitoring fitted? Thx
brucefxdl
4 years ago
reckon they will be 8 mm,grab a measuring stick and have a look.
Tags
4 years ago
I think its the rim hole that it goes by, It looks more the 11.3mm to me if its the rim hole, just wanting to make sure before I buy them. thx
Far Canal
4 years ago
Related to Dragz? perchance.
brucefxdl likes this post
DocGreen
4 years ago
Tags, they were 11.3mm for non cvo and pre tpms mate. I was considering getting the tpms for mine and would have had to buy seals from fobo to make the sensors seal, never ended up doing it. I did get a chrome right angle valve stem for the back wheel and straight for the front when I had the tyres replaced at an Indy workshop, no issues and most places would have them I'd reckon.
DocGreen
Tags
4 years ago
Thx Doc, yeh I found out that they were 11.3 mm and have bought some from mx store & are on the way, cheers.
