Online: beaglebasher
Too loud for some
  • rodsteph
    rodsteph
    4 years ago
    Looking at disposing of my 2009 VRSCAW. According to the CFO, it's too fast and I'm too bloody slow. However, in order to pass muster, in the opinion of Harley Heaven the noise level of my screamin' eagles won't get me the roadworthy I need to sell it. Have pulled out one of the baffles to take a gander and the measurements all seem a little strange. Certainly not in accordance with all the so called "quiet" baffles on e-bay and other suppliers. So, have decided to re-wrap in new fibreglass blanket after drilling a couple more holes (yet to disassemble and check out pipe). Was wondering if anyone has tried to quieten down the noise and if so, how did they do it without costing a fortune?
    4 years ago
    Get the oem muffers off eBay, gumtree, Facebook
  • rodsteph
    rodsteph
    4 years ago
    "Muffers" not the solution. 'Screamin Eagles' on my bike include pipes right up to header collector joints. Have no intention of sawing off the end section just to use slip-ons. No point. Considering buying ceramic blanket and re-wrapping metal insert sections. Have watched YouTube bloke doing it on his Indian and seemed to work. No point re-inventing the wheel!!!
    4 years ago
    Oem headers and mufflers are around and often cheap. I’d consider that an easier and more reliable option than anything else. And if you get hauled thru the pits, the oem exhaust system avoids all sorts of issues when they see other exhausts with other names on them and non-oem epa approval stamps
    Not many on here with vrods
    Good luck with it
  • rodsteph
    rodsteph
    4 years ago
    Problem. V-Rod stuff is not easily found and when it is advertised, not so cheap, unlike the Road King I had for nearly 20 years (apart from engine work done when first purchased). About the only thing Harley on the V-Rod is frame. Brakes are Brembo's, motor & gearbox Porsche, tyres anyone and rest is Chinese. Ohhh ... Harley Davidson have the company's name on it, so that's a start!!!
  • steelo
    steelo
    4 years ago
    A (bit pricey) exhaust system on NSW GT
  • rodsteph
    rodsteph
    4 years ago
    If you know what a v-rod exhaust looks like, that's only the header and collector. Another length of pipe is needed to reach far enough back and usually has mufflers welded to it (as in my screamin' eagle set up). The slip-ons also look like they came off a Night Rod, whereas my stuff is all chrome (my preference). Thanks for entering the fray, but I've decided to go the wrap route.
    4 years ago
    Quoting rodsteph on 08 Nov 2021 07:13 AM
    A really old trick to quieten a pipe for rego was to jam it full of steel wool before the baffle. Just make sure its not steelwool with the soap in it....
  • steelo
    steelo
    4 years ago
    Perhaps do it correctly. Problem as I see it is that the bike needs to pass muster to resell. I don't even think re wrapping the internals is going to cut it. It's OK if you are doing it for yourself and fully aware of the mods and consequences but it'll be an unpleasant surprise for any new owner. AND they know where you live..
    4 years ago
    Quoting steelo on 08 Nov 2021 10:15 AMedited: 08 Nov 2021 10:27 AM
    Hey lets not skirt around the issue here...if its a v-rod its likely going to be Habib from Lebanon whos going to buy it and take the whole exhaust off and roar around town anyway....just saying
